TractorLinks.com
Straw spreader bats worn out. Angle iron??
R Wyler
10-10-2012 16:26:15
Last year my Gleaner A put the straw in windrows so heavy I could not plow or disc. The spreader is missing one of the bats and the rest are worn down. What would be wrong with some 1" or 1 1/4" angle iron and possibly some paddles on them?? As it is it leaves such a windrow I have to burn, no other way of managing it. Any suggestions on what would work best?
R Wyler
10-11-2012 06:13:40
 Re: Straw spreader bats worn out. Angle iron?? in reply to R Wyler, 10-10-2012 16:26:15
Thanks for the response guys. I should have thought of using a belt. I will look around and find a bigger V belt to use. I do see how the steel ones would be dangerous. I must get it working better because it is windrowing.
rusty6
10-11-2012 08:06:29
 Re: Straw spreader bats worn out. Angle iron?? in reply to R Wyler, 10-11-2012 06:13:40
Yes, go with rubber. Years ago I replaced the wooden bats on a 460 Case with strips of rubber tire and they worked great. I cut out the ribs of some old triple rib front tractor tires and jst bolted them on in place of the wood.
R Wyler
10-12-2012 17:27:24
 Re: Straw spreader bats worn out. Angle iron?? in reply to rusty6, 10-11-2012 08:06:29
I will see what I can come up with. I need to get it done before the last minute. I have some time to get it done.
casecollectorsc
10-10-2012 17:57:40
JI Case used lengths of variable speed drive belt for spreader bats. You probably got an old v.s. belt laying around.
Fixerupper
10-10-2012 18:33:08
 Re: Straw spreader bats worn out. Angle iron?? in reply to casecollectorsc, 10-10-2012 17:57:40
Deere used old variable speed belt too. Works good and is safer than angle iron just in case you trip on a cornstalk and fall into it. I know, you aren't supposed to be in that area with the combine running but........ Jim
j hikemper
10-10-2012 20:48:50
 Re: Straw spreader bats worn out. Angle iron?? in reply to Fixerupper, 10-10-2012 18:33:08
ruibber only , cause scht happens , n o matter how careful you try to be
