Dave from MN
How long should the little pump make noise, when you turn the key on before it stops? I had a couple times were the combine seemed to lose a little power, then would be a little hard starting, after shutting down for a short time. Otherwise she fires right up, temp depending, german diesel ya know. When I was checking it out yesterday, I turned key on and the little pump ran for quite some time, and seemed kinda loud, ticking and such, tapped a few times, still made noise. Turned off key for a bit then turned on and it didnt make noise, but started easy. any advice
