Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: john deere 4400 combine
semper fi guy II
10-05-2012 04:36:08
JD 4400 329 diesel with Roosa Master pump has an elbow fitting made of brass coming off the pump for the RETURN line to the tank
Symptom: engine ran good for a while then ran weak and died, would not run full throttle
Reason....pressure inside the pump builds up and a check ball is INSIDE this FITTING. Crap clogs up this check valve ball/spring, (crap might be from pump deterioration of internal plastic parts) To remedy: take the elbow off and use compressed air to blow the crud out, reassemble and try it again. This info came from a JD tech and it worked for us... Fingers crossed that this will help somebody out there
Copyright © 1997-2015 Yesterday's Tractor Co.
