TractorLinks.com
Re: JD 4420 Feeder house upper variable speed pulley bearing
JDseller
09-30-2012 21:22:34
Those bearing usually last a long time. Check and see if the hole in the housing is worn letting it have additional side load. I have only replaced one or two of those bearing on all of the combines I have ever worked on. So they are not a big wear out item. You have something causing it to go out.
andy r
10-01-2012 06:39:26
 Re: JD 4420 Feeder house upper variable speed pulley bearing in reply to JDseller, 09-30-2012 21:22:34
The pulley I am talking about that the bearing has went out in is the same one that has the roller bearing inside of it. The roller bearing runs on the shaft coming off of the combine. Roller bearing seems ok. Shaft coming off of the combine which the roller runs on looks ok too - shows a slight amount of wear. I am like you, with the size of the bearing it should last a while.
