TractorLinks.com
Re: jd 45 rattle chain plugging
Bradley K
09-26-2012 20:09:43
For corn you definitely should have the smaller sprocket, (driven), to give more capacity. On my 95 I ended up welding the slip clutch solid.
When I bought this machine the owner said the only thing wrong was it was it needed the nut and spring for the slip clutch on the grain conveyor, (raddle) chain. I put those on from a donor machine, but could not get it tight enough as the threads were stripped on the shaft.
Figured my only options were to take the shaft out, and get it rebuilt; or do the welder fix. There is still a 5/16 bolt, (or maybe 1/4), don't remember now, that attaches the sprocket-slip clutch assembly. My thought is that is still protection against totally wrecking stuff.
Anyway, welded that solid and it worked great, also it does have the high speed sprocket.
DeltaRed
09-26-2012 20:46:34
 Re: jd 45 rattle chain plugging in reply to Bradley K, 09-26-2012 20:09:43
Welded?You moron! those clutches are there a reason!The first time it hangs up it tear holy he!! out of everything!Then you will be buying another combine.
sdc eastern ia
09-27-2012 06:54:24
 Re: jd 45 rattle chain plugging in reply to DeltaRed, 09-26-2012 20:46:34
Thanks for the chuckle today. For some reason I feel like welding something up today.
Bradley K
09-27-2012 05:59:55
You can say what you want, if you want to get into bashing other people's ideas; that's fine.
I don't know how long you have been running older equipment, but I would presume it is long enough to know that sometimes unconventional fixes need to be used.
In case you didn't read thoroughly enough let me reiterate the facts.
#1. The shaft would need to be removed and replaced or the end with the threads built up and rethreaded.
#2. The whole assembly is attached to the shaft with a bolt which will act as a shear bolt in the event the chain breaks or it is plugged. I was a little reserved about welding this solid, and wouldn't go recommending this for every slip clutch problem; but in this situation a backup situation does exist.
#3. This fix was done among others, I spent at least a week going over this machine. If I were to list all the repairs, improvements, etc; that were done before the machine went to the field it would take a page or so. This machine left the shop and harvested my 2012 corn crop without a single breakdown.
Thank you for your concern, but this was not a moronic farmer fix.
Bradley K
DeltaRed
09-27-2012 06:47:06
 Re: jd 45 rattle chain plugging in reply to Bradley K, 09-27-2012 05:59:55
I been running old wornout equipment for my entire 'career'-over 35 years.So I am well adapt at some unconventional fixes.Welding slip clutches is not one of them.I just this spring bought a JD feeder house that was torn to holyhe!!.The conveyor chain is a wadded up mess(not repairable)The main shaft(1 1/2") is bent,the front drum shaft/bearing holder bent,as well as other damage.Dont know what happened-wheather the chain broke or they ran something through it.The slip clutch was rusted up and didnt slip,thus destroying the thing.So I 'm sorry for offending you when I read in horror of the welded clutch
Bradley K
09-27-2012 07:13:58
 Re: jd 45 rattle chain plugging in reply to DeltaRed, 09-27-2012 06:47:06
The feeder house would be a completely different story. There is no give after the slip clutch on that application.
I am just telling you what worked for me, I appreciate your input on the subject. What I am trying to explain is that in this situation there is a mild steel bolt that would easily shear before damage was done, totally different than in most applications.
DeltaRed
09-27-2012 07:46:08
 Re: jd 45 rattle chain plugging in reply to Bradley K, 09-27-2012 07:13:58
Go back on this forum a page or two.There are several posts with pics of that feeder house,etc.Really glad your combine is 'protected' :)
DeltaRed
09-27-2012 07:03:00
Forgot to say..Started with an old 55RB in late 70s,ran a 45 sb for years.Currently own the old 55,a 95sb,a 105Corn speacial.I have just purchaced a 105R diesel.The intermidate feeder house that was destroyed is from a 95.
JMS/.MN
09-26-2012 20:17:19
Welding a slip clutch is always a great move......
