Topic: Re: john deere 4400 combine
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Dalet
09-26-2012 18:33:33
184.94.141.146
I did unscrew the elec to the pump and it wouldn't start until I touched the wire back to the pump. Started right up then.
UPDATE: I took the check valve off the pump and let it run a gallon or so through the pump to flush out the crap. Then I assembled the return line without the check valve to send the crap to the tank and let the sediment screen and filter deal with it.
I have 50 acres of beans left and just want to be done with this machine for now. What problems can I expect by doing this? |
| JDseller
09-27-2012 08:21:03
208.126.196.144
Re: john deere 4400 combine in reply to Dalet, 09-26-2012 18:33:33
| | The dampener ring is already falling apart and plugging your injection pump. With the check valve out the pieces will return to the tank for a awhile. It still may get plugged up enough to quit running. The internal passages plug and they will quit pumping. Also it will more than likely drain off over night. You may have to bleed the pump before each use. That is what the check valve keeps from happening. The kit to repair it is under $50. You have to have some knowledge on how to completely dis-assemble the injection pump. Then clean it all out and reassemble it. I also usually replace the old style governor cage. The old style has the rubber ring that hooks over two rows of rivets. That ring is what is falling apart. The solid steel governor cage does not have that rubber ring. I have been doing that for 25 plus years and never had an issue with the new steel cage. If you look on line there are getting to be cheaper places to exchange injection pumps on line. The local repair shops make them perfect again and that costs you $700-800. I have seen the exchange guys in the $350-450 range. I would repair the one you have or exchange one that has been rebuilt. Getting another used pump might just do the same thing in a short while. |
| pulling kid
09-27-2012 19:08:59
174.124.119.64
Re: john deere 4400 combine in reply to JDseller, 09-27-2012 08:21:03
| thanks to jd seller i removed the check valve and hooked it up without it it starts and runs fine, tomorrow i will combine i think it will work. Do i need to fix something? |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
