Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 9500 unloading drive shear bolt
gbs
09-25-2012 15:56:46
not familiar with the 9500 but unless your unloading on the go slow the engine to engage the auger then speed up to desired speed this greatly reduces the shock loading on the auger drives,check auger flights for wear,if the unload auger is worn to the point that it can't move the grain away from the tank auger fast enough it will cause excess strain on the auger drives,on several makes you can adjust the flow going into the bottom auger inside the tank that will allow you to take some load off the drives
