Double elevator Case mounted Corn picker ( Photos too)
JDseller
I was at the Mt Pleasant, Iowa, Threshers Reunion today. There was a real sharp Case DC with a two row mounted Case corn picker on display. I have only seen two other mounted Case corn pickers. I have never seen one with two elevators. What model is this one. My hat is off to the owners as it is very clean.
it is a model IM, a friend in eastern sd has one on a dc, not one of Case's better designs, he said you can't see the rows or hardly can see where you are going for that matter and wouldn't be able to tell if one was plugged up,the picker if offset to clear the steering arm requiring a cast spacer ring on the LH rim
