Anonymous-0
Is it possible the slant 6 is ONE distributer TOOTH Notch out of Time, They are KNOWN to be TUF Engines that will perform and start in Nearly All conditions ,,, As Long As I have Owned this 300 Massey Combine I have suspected It was FIRING TOO Early , But have Resisted Moving the Distributor ,, IT IS COCKED NEARLY AS FAR AS IT CAN GO one way , AND IT HAS RUN OK in the past. Always Made Me Wonder if It was going to start . Once started , It seemed to Work OK ..Although a bit Bratty ( Yankn the Governor And Giving it Hale )When Working thru a hard Pull... But honestly It is Not The Fuel mizer the 1968 300 Massey is .... Son Came over today , and together we made that slant 6 Fire up... None Of Us Are Truly satisfied with how it Runs ,After new MSD coil , rebuilt carb, New points and 2nd condensor out of parts drawer , and a swap out of suspect spark plug wire, all improved the Way it ran, but it still don't seem RIGHT .. changing 3 resisters made no difference ..
