1460 IHC Harvester gauge problem
jakrause
New User
Volts, gas, oil pressure not working. Pulling out the individual gauges and testing the contacts show voltage. Two new gauges put in last fall. What else can be tested?
harnes and the sending units, i usualy groud the terminal on the temperature wire,if it reads all the way hot replace the sending unit,if it doesn't check your harness.most machines run this way.
