Put the bushings in so I could bring her home.
Bad bushing split in center all the way around.
Using cam bearing tool to install wheel bushings.
Had to use a little lock tite.Hub was worn a little did not have much press.All worked will.Thanks Tom at Yaz all crop for the fast service.BlaineF(WA)
