MH 35 Fuel pump
1031D
Are these available or do you have to rebuild them? Bought one that's been sitting for a bit and it doesn't work.
Try www.jackssmallengines.com and put part # 223307m91 I got one from them. Because the tank is so far below the engine, you could have problems getting the pump to prime. Either remove breather hose and pour gas directly into the caburetor or you may do what I did i put an electric fuel pump between the tank and the mechanical pump and pushed the gas to it. I used a 6 volt pump and this works everytime.
