b1 allis garden tractor wiring diagram
Jimmy Cox
New User
Rats chewed ignition wiring, anyone have wiring diagram for the B1 allis Garden Tractor? Trying to get this running for my Grandson.
Thanks
A far as ignition wiring there is only the wire to ground out the ignition to kill the engine. If you are looking for a complete wire diagram try I think simplicitytractors.com You might also post on the Allis sub-form. What Briggs engine does your tractor have, Model 19 or 23. If so you will most likely have a bad coil. The symptom of a bad coil on these engine will make you think you have a carb problem.
Kent
