danofarming
I have a Massey Ferguson "2722" made by Simplicity. It has a 22 horse Briggs Vanguard engine. With a fully charged battery, new this spring, it will mow for 2 hours and then not start. I put the trickle charger on it and am going to charge it overnight for a fully charged battery and then check the charging output in the morn. Possibility #1 The charging circuit does not put out enough to charge the battery and pull the electric clutch while mowing. Possibility #2 The electric clutch is bad and drawing too much juice.Possibility #3 the charging circuit is bad. Does anyone have any thoughts or input?
