super99
Does anyone have a service manual for a JD LX176? Mine is leaking oil out around the gasket on the bottom of the motor and I started to take the motor out to fix it. I need info about removing the clutch and pulleys, getting the hydrostat drive belt off. Does the muffler have to come off, or can you pull the motor with it on? I changed this gasket about 5 years ago, and can't remember what all I did to remove the motor. It sucks to get old!!! Thanks, Chris
