Britcheflee
I have discovered that it appears that PO installed a coil which requires a ballast resisitor (coil says for use with external resisitor) when a resisitor was not installed - the PO said that after some work on the engine it ran well for a while then did not run.
I was able to get it to run but it ran bad with a bad misfire and eventually yesterday noted a weak spark and intermittent spark. I changed out the condensor but left the points alone as I thought they were ok - still ran bad so today (weather permitting) will change out points.
My question is: how quickly would this incorrect set up affect the new condensor (I probably ran it for about 5 mins)? Which would be better - to install an in line resisitor or install a different coil.
This is on a wisconsin TR10D engine - single cylinder - I believe it is magneto/coil set up.
Thank you,
Lee
Thank you,
Lee
