Anonymous-0
I've got a Sears Suburban with the HH 120 Tecumseh engine. It has had a slow oil leak for some time that is getting worse. Oil leaks from under the engine and down left side of tractor frame (flywheel side). It leaks even when sitting for long periods. When the ignition went bad it didn't run for about a year until I could find parts for it. We pulled the engine off and is dry behind the flywheel so crank seal is OK. Engine is sitting on a papertowel now after cleaning the bottom off real good. Is there any trick or secret for finding an oil leak? I know they make a dye to add to the oil but don't know anybody that sells it.
Thanks, Bob
Thanks, Bob
