Ignition Points Cover
R. Kilts
New User
I have a Pennsylvania Meteor 1012 with an HH120 Tecumseh motor. I need either the cover for the points or a tracing of one so I can make my own.
I surfed the 'net a bit and they apparently aren't REAL easy to find.
Try the Tech Forum over at www.perr.com. LOTS of Tec GURUS over there.
On the other hand, it shouldn't be REAL tough to make a tracing of the points box on paper and transfer it to metal.
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/TechPointsCover.jpg">
Are you talking about the cover under the fly wheel,that has the coil.I may have one.I am in Va.I don't know what model tec. it is off of as I just put parts in box when I tore engines down.If they could be repaired they was,if not used for parts.Still have some tec.parts.
