Anonymous-0
Still having problems with the Kohler model CH25, 25 hp engine that has about 400 hours in the Vermeer chipper. It starts and runs for approx one hour until it get hot, then the engine misfires and is unable to run the chipper. Removed both plugs and they look great. Replaced the fuel pump and it ran OK for one day when the ouside temp didn't get above 20 or so degrees F. Originally purchased the machine/engine when it had about 370 hours. Low idle was never really very smooth, but high idle and under load it was OK and we ran it for about 20 hours. Although initially thought we had the problem solved with the new fuel pump, it only lasted for that single day before the hot misfiring problem resurfaced. Again it will start up OK and run loaded for 20 minutes to approximately an hour before it begins to misfire and loose speed. Never really dies, but can't pull much load. Occasionally it might recover for 10 seconds or so, but this recovery is always very brief. Let it cool down for 45 or so minutes and it will run OK again for 15-20 minutes before acting up. Went on the internet and viewed the service manual and apparently this engine has the advanced version of the Capacitive Discharge ignition with SMART-SPARK, or in other words, a timing advance module. I originally thought it was a fuel supply problem, because when the engine started to run rough, applying the choke appeared to help. Now not so sure. Plan is to replace the plugs although they look OK, and also replace the fuel lines which also look OK, because they are relatively cheap fixes before looking at the ignition modules. Hoping someone has some good insight on what is likely the problem or a good approach to determining the problem. Thanks for any help/advice.
