carb freeze
Anonymous-0
my 560 will sit and run all day but give it gas and go out though the feild and the intake or carb acts like it freezes up and dies. even on the hottest days carb gets very cold and with a little chock will start right up .have set the carb over and over same thing all the time. took the intake apart every thing seem fine. whats wrong
Put a little gas line anti-freeze; Methanol, Heet, In you fuel will limit your problem. If possible you could run a line near the carb with engine coolant in it to heat the carb. Warming the intake pipe between the air filter and the carb. with engine coolant will do the same thing.
Kent
