Britcheflee
Well, lots of success today. Got the correct belt for the genny and installed that, put in new solenoid and wired that up as well as installing new switch this has 3 posts as compared to 2 post on old switch but with advice from local tractor repair guru got wiring set up so it works. I was careful to ensure that the black wire from the switch came from the post marked M and connected it to the small nut on the throttle plate (which has an insulating washer and is supposed to run to the magneto to shut it off)...well...nut is there but there is no wire from that nut to the magneto....plus, I have been looking everywhere but cannot find where the magneto is located. This is the Briggs and stratton 7 hp engine. Can you advise as to the location of the magneto and what I need to do to get that wire attached to be able to shut down the engine. I can do it by the ground post on the spark plug but really want it to be wired up right so I can stop and start it without raising the hood - particularly in an emergency situation.
Thank you,
Lee
Thank you,
Lee
