TractorLinks.com
Bolens Huskey 750 starter
Britcheflee
11-14-2009 23:32:37
Please keep an eye out for a starter for my bolens huskey 750 lawn tractor - I got the tractor from my father in law and the starter is not attached although all wiring is - maybe it stopped working and it was removed - tractor starts ok by pulling with rope on main front pulley but tired of doing this....searching e bay now and then but so far no luck.
If you have one, or see one for sale please let me know.
Thanks,
Lee
Bob
11-15-2009 14:56:57
 Re: Bolens Huskey 750 starter in reply to Britcheflee, 11-14-2009 23:32:37
Have you been to the Sonny's Bolens site?
If you haven't, it's a worthwhile "surf" for any Bolens owner.
chuck in IN
11-15-2009 12:59:11
E-mail me .i have a starter generator that will work for you.$50 plus shipping
Britcheflee
11-15-2009 08:19:58
 Re: Bolens Huskey 750 starter in reply to Frank(ky), 11-14-2009 23:32:37
Thank you all for your help - yes, it is the older Bolens Huskey (tube frame - will get info later when frost burns off) - I am sure it is the starter/generator type as it is belt driven and I do not think it has a separate charging system - I would be interested to know how this works - does the battery drive the generator to start the engine until it turns over and the generator then becomes a charging system rather than a starter?
Actually - herre is a picture:
Final question - I am assuming this is a 12 volt system?
Thank you for your advice.
Lee
El Toro
11-15-2009 09:25:03
 Re: Bolens Huskey 750 starter in reply to Britcheflee, 11-15-2009 08:19:58
That's the way the S/G works. Hal
El Toro
11-15-2009 07:56:09
Call you local repair shop the rebuilds starters, generators or alternators to see if they have a S/G for your tractor you will need the Make & model number of the engine since some S/G"s turn CCW, but mine turns CW used on this old Wards tractor. Its painted black in this picture. I had it rebuilt last year with new bearings & brushes and they machined the armature.
Call this toll free number to see if they have a spare Delco S/G. Hal
1-800-858-8517
jdemaris
11-15-2009 07:00:01
 Re: Bolens Husky 750 starter in reply to Britcheflee, 11-14-2009 23:32:37
It used a very common Delco-Remy starter generator. Easy to find and used on many other tractor brands. 750 was one of the few tube-frame Bolens with a aluminum 7 horse Briggs & Stratton engine. Briggs engine 170402 or 170401.
Starter generators were common during that time period because they can be easily added to rope-start engines.
If you don't need it to look original, you can also put a regular starter motor on it - instead of the starter generator - but that requies a different flywheel. It also leaves you with a starter but no charing system.
Dannie 1
11-15-2009 05:42:44
What type engine?
Tom TX
11-15-2009 05:01:17
What brand, model engine does it have? Tom
