hydrostatic trannny oil
i have a roper hydro 16t lawn tractor , the tranny fluid is low and it asks for TYPE F not sure what type f is or who makes it and where aval. AS dumb has it sounds all i know its red and smells like hydraulic oil. Got has far has changing the filter which was a cummins hydraulic oil filter HF6057 .any help or thoughts would be very much appreciated thanks. CAM
Type F is an automatic transmission fluid used mainly in older Ford transmissions. Should be able to find it most auto parts stores.
When I changed the ATF in my Wards tractor they recommended Type F & I installed Dexron III. It's
38 years old and I'm still using it. It has hydraulic lift too. Hal
Welcome to a new colour. Type F is green. It was developed for Ford back in the sixties. You should be able to find at any auto parts store such as NAPA
Type F is not as slick as Dexron and won t slip as much, the hot trick in the 70s was to run F in your GM tranny, made it shift a little harder.
