Dad picked up this tractor from a neighbor in hopes of fixing it up to seel. The tractor came to him with a broken shift lever, which he was able to weld back together. the previous owner told him that the tractor runs fine, but sticks in gear. We replaced the transmission belt, as it was a bit taught even with the clutch engaged. The new belt has sufficient slack in it, and the allow the transaxle to be "unloaded". This didn't solve the problem. the mower can be placed in gear prior to starting up the mower, you can motor around in that gear without any noise/problems, abut shifting out of gear is impossible without shutting the tractor down, and sometime rocking the tractor.
We pulled the transaxle apart and inspected for damage. with the exception of a couple of nicked shift keys (probably from attempting to ram the unit between gears that ultimately broke the shift lever) everything looked good. No wear/breakage in the gears or sprokets. the keyways were perfect and everything was sufficiently lubed. There was no play in the input shaft. We replaced the shift keys, cleaned out the old lube and re-lubed with the recommended amount of Bentonite grease. dad reassemble everything yesterday and took it out for a test ride and nothing has changed...says it will shift when the until is off, but not once the engine runs...we're at a loss - the transmission belt is slack, and there is no "pwer" to the tranny - what gives? :x
we have a couple of ideas of things to try, but they seem to be shots in the dark (going to disconnect brake to see if perhaps brake is misadjusted and engaging before clutch has unloaded transaxle, causing binding...also will check torque on transaxle case bolts - dad's torque wrench was "mis-filed" when we put the case back together, but he has managed to locate it...)
Does anybody have any suggestions? Any and all guidance is deeply appreciated.
