hydrostatic and pump CC1720
Anonymous-0
I have a CC 1720. Engine runs but rear end will not move unless dump valve is engaged. If engine is running and dump valve is engaged tractor will move forward only. Any ideas as to what the problem might be as well as an answer to what fluid and weight goes in the pump would be appreciated. Dealer thinks its 15-40w Sundstrand say Type F trans fluid.
