Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Cub Cadet adjusting belt tensioner spring/pulley question
Al Duresa
05-15-2009 05:58:53
Hi - I have a cub super garden tractor Model 1872 and the adjustment bolt/screw for the tensioner spring that ultimately places tension on the pulley system that comes off the engine and drives the deck has got me baffled. What is happening, the pulley that is also connected to the tensioner spring is moving out and coming in contact with the big bracket that is used to hook up your plow or snow thrower. If I adjust the screw all way in the pulley works its way out and same goes if I adjust the screw all the way out. Its like it does not have any affect on the spring. The spring is a heavy-duty thing that looks like there is no cracks and I would be surprised if the spring lost some of its spring force due to its size. I have checked the belt to make sure I did not swap it with the deck belt accidentally and that is good. Sooner or later I am going to fry that pulley.
ANON
05-16-2009 13:18:20
 Re: Cub Cadet adjusting belt tensioner spring/pulley ques... in reply to Al Duresa, 05-15-2009 05:58:53
Make sure your two pullies are moving independent of each other. I have had the pulley with the adjusting bolt rust fast to the cross shaft and not be able to adjust belt. Second, make sure the belt is the correct size. If everything is correct, belt should drop straight down from PTO pulley to the transverse pulley that shoot belt back to mower deck.
Old Roy
05-15-2009 20:52:39
Do you think the belt you are using may be stretched ?
the only way I know to adjust the belt is [Looking at the motor] driven "clutch' belt has to be in line with the grove on both sides.
Copyright © 1997-2015 Yesterday's Tractor Co.
