Not very often that I visit this area of YT...but I am hoping some of you folks that fool with lawn tractors might be able to point me in the right direction.
First, I am like Sgt. Schultz when it comes to hydrostatic drive components.......I Know Nothing (about them)!!
I have been thinking of trying to convert my Farmall Super A to hydrostatic drive. Cramming all the components inside the torque tube is the challenge. It may not even be feasible. But, if the clutch is removed and the pump attached to the engine, there should be enough room for a hydraulic motor ahead of the transmission...or maybe the transmission can be done away with entirely.
Inquiring minds will want to know why I would consider doing this......it's because the Super A is geared too high, and from what I can see there isn't enough room in the transmission case to fit a lower (larger diameter) first gear. This old offset is great for cultivating the garden....but it needs to be able to crawl when the plants are very small, so you don't cover them up as you cultivate. When the crop gets to be 8" or 10" high, then you can use the speed to throw dirt in around the plants...but it works against you when they are small. So...what kind of hydrostatic/hydraulic motor and pump would I have to get.....assuming this is a feasible project? I don't know how they are rated for horsepower or torque or GPM, etc., etc. Obviously, I'd need something capable of standing up to the task.....but I don't know what that is. Thanks for whatever you can throw my way...as long as it isn't rocks...hehe!
