bolens 1400 deck bearings
d swan
New User
Does anyone happen to know the bearing numbers for a bolens deck model 18300.I had the bearing out of the spindle but can't make out the numbers even with a magnify glass.
Do you have a calipers?
Measure ID/OD/Thickness, if you don"t have a
bearing book, somebody here will tell you.
Also, its probably a metric demension.
i don't have the actual bearing number handy, but I can tell you the bolens part #. You might be able to cross that with someone.
1185828, also try 1185-828
its a prety common bearing, I got some from Stens once, and my local John Deere dealer was able to cross and match them up from there stuff also.
