Hey, come on guys, help me out please?//
Farmallb
Ive asked questions in I mpliment alley, the Case, JD, and IHC forums and always got several answers. I posted a bunch of questions about my MW 2 wheeled garden tractor, and not a response. Did I ask too many questions. Please help me out. Ive never owned one before, but ive wanted one since I was 10. The questions now are on page 2. Please take a look, and give me some idees. Thanks.
Dont have a foggiest what iss classic or modern view. I just saw it tonight on 2nd page in the middle, on what I would guess was standard view
Maybe others are not as bumb as me, but I cant find your referenced post, by looking back a couple of pages. Why not start over and repost at the top of this page, as a new topic, and clearly ask for what you want. Tom
#1 What is the adjustment crank on the plow for. I would think, if it went too deep u would raise the handles, and if it went too shallow, you would bear down on them. There is no depth wheel, So, whats the crank for. #2 How do I clean the mesh upper part of the air cleaner? #3 What Wgt oil does the engine take? #4 What wgt oil does the trans take? #5 What is the big hand wheel/knob located up from the frame between the engine and trans for? # 6 What is R hand knob handle at the comtrols do? Mine isnt connected to anything. #7 Can I get an op manual? #8 Was there ever any made with reverse? #9 How much air in tires? #10 Dont remember Wards tractors as haveing hoods. Am I right? #11 Big knob controls are marked R & L. Is this for assembly purposes only? #13 There are 2 , 3in V belt pulleys mounted away from each other around 10in, the free end raiseing up about that far, and the fixed end mounting to the e ngine. On the free end, is fixed a cable of short length attached to a rod ending up at the controls as a knob. What is it for, Theres a belt between the pulleys, and a spring on the fixed axle to bring the other free end back down upon release of the knob. #4 What is the 3/8 rod comeing out of the gear case and running to the Right axle for? AND, what is the spring running around the right axle at the wheel base for. #15 Whats I & L on the engine oil dipstick mean? #16 When I check the engine oil, or the trans fluid, do I screw the plugs all the way in and back out to check, or just set them in the holes and pull out to check.?
