Anonymous-0
Hi Fellas!
I have a honda 3813 that threw its timing belt off. I have a new one and have stripped down (the engine...)to try and replace it. there is a SINGLE set of marks for the crankshaft to align, and a mark on the case for the cam sprocket to line up with, BUT there are 2 sets of 2 marks on the cam sprocket (both are marked "F" & "T")spaced 180o apart. Anyone have a manual that tells which mark should be matched to the one on the case? HELP!
THANK YOU SO MUCH! - Michelle
