Snowblower for Case 222
Ron Darr
New User
Does anyone know if there is a snowblower which
will fit Case 222 garden tractors. Can any of
the newer blowers be adapted to fit?
Thank You
Case / Ingersoll did make a blower for that tractor. I have one, but am missing some of the attaching parts / instructions how to mount it, so have never had it on.
as for anything new made today, I don"t know... But look up nearest ingersoll dealer and see what they come up with.
Ingersoll owns the case garden tractor division.
Case made a 38" wide, single stage snow thrower specifically for the 200 series tractors built from 1971 to the end of the series in the early 90's. There is also a 48" wide version that was built for the 400 series tractors but it will fit the 200's with no modifications. Case did not recommend the wider model for 200's with less than 14 hp but I have heard from several 12 hp owners that they have no problems spinning the wider unit.
Over the years, minor changes were made to both models and as these changes came about, the first letter in the model number advanced from J-38 to K-38 to L, M, N etc.
There was also a kit available for the 38" model that widened the overall cut by adding "wings" on each side of the housing so if you happen to come across one that has these wings on it, you'll know that it isn't some weird model.
The latest offerings from Ingersoll begin with the letters SB, as in SB48 or SB38 and while they'll fit on your machine, they won't work. In the early 90's, Ingersoll turned the engines around 180 degrees and that move meant that the crankshaft rotated the opposite direction for the purposes of the power take-off. Ingersoll had to redesign the mule drive for the blowers so that they would spin correctly. And the traditional left discharge mower decks became right hand discharge decks. They too, still fit on the old tractors but won't work.
Used SnoCasters show up on e-Bay all the time and you can expect to pay up to $400.00 for something decent. Just make sure that it's complete with the chute crank handle and the L-arm that attaches to the lift bracket on your tractor and also supports the chute crank.
Too bad you're not in southern Ontario because I could sell you either model. LOL
Don't use anything but OEM drive belts. You can buy them on-line from Ed at the link below.
Craigslist and Kijiji are two local places to watch for used ones or even advertise on for free.
Ed
Thank you for the information. I am new at these older tractors and am finding things can get rather confusing. In Case letters I find snowblowers and SnoCasters being described. What is the difference? Can I use a SnoCaster on
my older 222"s. My model is a 9657670 which I
think is a 1957 model.
Thank You
Ron
Ron,
Since I posted a fairly detailed reply over at the Yahoo site, there's no need to duplicate it here. Cheers, Tom
Tom, I really appreciate all of your help. As you can see I am not only confused by the Case
numbers but also the various sites about garden tractors.
Thank You Again
Ron
Hi Ron,
If your interested I have a very nice Case 38inch snowblower for my Case 224 that I don't use and would sell.
I am interested in a snowblower for a Case 222 Tractor. About 10 years ago I bought what I now believe was a'Snowcaster" This had large drum with helical blades attached which were supposed to pick up the snow and channel it to the central spout. I believe it was what is termed a single stage blower. In any event it didn't work worth a damn and I'm looking for what I think is termed a Two Stage Blower, i.e. a conventional snowblower. I,m in the Trenton area of Southern Ontario if anyone can help.
