Anonymous-0
bought a tx1300f and put a rebuild clutch in it. worked good for a tour around the sub. then i hooked the tiller up and it worked for just awhile and the same problem. its like its stuck in gear or the clutch is only going patially in. i looked at it through the peep hole and when the pedal was pushed in it traveled to the bottom, but an 1" from being fully disengaged. then it pushed against the plate a little. it seems to have the right adjustment at the top then goes in and the tractor kinda goes and not. tyhats why i put a clutch,thr,plt in it. can some give me some ideas? have the manual but that's pretty much useless when coming to trouble shooting. thanx gary
