Hey gang,
An elderly friend of mine has a 1968 Cub Cadet 122 with the 8hp Kohler. He's not able to work on it anymore, so this evening I trailered it back to my place.
I won't have time to really check it all out until this weekend, but here's the deal:
The tractor starts right up, and runs very strongly... for a while. After a short period of time the engine will stutter briefly, backfire once or twice, and stall.
This happens after 1.5-2 minutes when idling.
It will do it after about one minute while in gear and moving.
It will do this after about 40 seconds if the mower is engaged.
These times are always very repeatable. If you try to start it back up right away it backfires repeatedly, and won't start. If you wait 30 seconds to a minute, it'll start right back up just fine and repeat the above ordeal.
I'm thinking a stuck needle valve, or hung up float. This will obviously be the first thing I check out.
Thoughts? Anything else I should keep my eyes peeled for?
Thanks!
-Parke1
Thanks!
-Parke1
