are rototillers legal on this site?
fredmich
I know you some of you guys work on tillers but I never see any posts on here! Is there another site I should ask my little honda fg100 tiller question? Mine is not a engine question but a transmission question. The brass gear on the shaft that the tines are attached to is shot. Everything else is OK (the shaft and housings). Nowhere can I find where they sell that shaft and gear without buying the whole transmission which is a little over a $100. Does anyone know where they sell the shaft and gear? It"s a easy fix if I had the parts. Thanks and sorry if I"m on the wrong forum...Fred
I'd look for a shop that sells Honda mowers, and go pick their brains for the info! By a shop, i mean some place other than Sears, Leows, HDepot! Those folks only know that you turn a key and it starts--no idea what causes that noise when it cranks!
Thanks for your reply. I thought I had offended someone because I wasn't sure if I was on the right forum when I didn't receive any replies which is what I was trying to avoid in the first place. However on searching the web I found alot of info. reqarding my problem on a Garden Website. From the posts on that site I was able to find a source that sold the parts I needed. Evidently this was a common problem with this model. Honda supposedly addressed it on the newer model FG110. Now I'm trying to find out if I can use the newer design on my tiller which is cheaper. Thanks again for the reply....Fred
Aww, don't worry, Fred! We're just a big, happy, bunch here, who like to help folks with their problems. If we know the answer to your question, we'll answer it, no matter what it might be, if we know it.
So, ask away! And, stay around and read the messages--might help you with your other machines!
Rusty J.
