This is a CC 1512D, and besides this one little hiccup, is a nice little tractor.
The problem seems to stem from the the glow-plugs. When ever they're on they seem to draw quite a bit of juice which due to the fact that they're on when the key is in the start position drops the voltage to the point where my solenoid wont kick in.
When the plugs are not on (key in the off or run position) my muti-meter reads a healthy 12+ volts, when the plugs are on (key in the plug warm or start position) the voltage drops to 9 - 10 volts. I should also note that when my amp meter always pegs to the discharge side when I'm in the glow-plug warm or in the start position.
The other kickers is that it seems to be worse when the tractor is warm, let it cool down and usually it will start.
I know glow-plugs are going to draw a lot, but to the point where it drops the voltage by 3 volts?
Any ideas?
Thanks,
K
Any ideas?
Thanks,
K
