Bolens Drive Shaft Universal Joints
Dave Ulm
05-21-2008 07:03:10
I have a Bolens Eliminator 1402, model number 1467, SN# 0100523. The front universal joint of the drive shaft is badly worn. My Bolens dealer shows the drive shaft is available, but at $500. The tractor isn’t worth spending $500. I just use it to drive around. Does anyone know where I can get just the universal joint? A part number would be helpful.
Tradititonal Farmer
05-22-2008 07:43:34
 Re: Bolens Drive Shaft Universal Joints in reply to Dave Ulm, 05-21-2008 07:03:10
Post what type of end the shaft has and the rest of the demensions of the whole shaft end.I have a buch of Bolens drive shafts of all different types probably can match one up.Also there are usually Bolens shafts on ebay
Kentb of SWMO
05-22-2008 06:20:05
The smallest joint the local farm supply had around hear was a 15/16 inch cup I think. I was building a driveline for a Gravely I have that used 7/8 inch. I had everthing built when the Gravely yoke threw me that undersized cross cup but I was lucky as I was able to set-up the Gravely yoke in my mill and bore the yoke out to use the 15/16 inch cross kit.
Kent
jdemaris
05-22-2008 06:43:04
 Re: Bolens Drive Shaft Universal Joints in reply to Kentb of SWMO, 05-22-2008 06:20:05
Smaller joints are available. When I worked for a Bolens dealer we stocked the replacement joints. And, I've bought them aftermarket. Many companies make joints with 7/8" caps and smaller. Bolens used Rockwell joints as I recall.
I don't remember the exact Bolens size - but in regard to U-joints with caps smaller than 15/16" - here are a few:
Rockwell 1FR series - cap diam is .875" (7/8")
NAPA # 853
Rockwell L10N series cap diam is .875" (7/8")
NAPA # 870
Nissan - cap diam is .875" (7/8")
NAPA # 392
Toyota/Kubota - cap diam is .788"
NAPA # 410 or 397
Leland
05-21-2008 20:27:47
have a welding or drive line shop weld a new yoke on it that uses a standard u joint .
Jim H. SW-PA
05-21-2008 08:00:12
I would suggest you go to TSC, I know they have parts and you could probably have one made cheaper.
Bob
05-21-2008 08:05:33
 Re: Bolens Drive Shaft Universal Joints in reply to Jim H. SW-PA, 05-21-2008 08:00:12
I doubt TSC has anything that small.
If he can tell us what type of "U" joints he has and dimensions, I can find them in a Precision "U" joint catalog, and come up with a number that can be ordered through many auto supply stores.
Bob
05-21-2008 07:17:47
Are the "U" joint cups held in place by snap rings?
