Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Power King Tractor 1970
Jeffrey E. Kennedy
03-23-2008 04:35:51
I'm needing the wire diagram on the switch- behind dash.This tractor has pointless ignition on it.The switch has 5 prongs on it.Need to know what wires go from the markings on switch to where at on the starter rec. or alt. box.The tractor only gets fire at plug when you touch wire from bottom of coil with an tester.That is giving it a ground I suppose.Don't know,all the wire diagrams don't really show me what I need.Anyone have any clues?Thanks for any info.
Cardinalsfan
04-25-2008 10:38:59
 Re: Power King Tractor 1970 in reply to Jeffrey E. Kennedy, 03-23-2008 04:35:51
Do you still need helpwith this. If so I will make some scans of my manual. I have a 1614 and the manual shows an electrical diagram with a 5 prong ignition switch. I am not even sure of the year. My manual says "after serial number 48140". I just inherited the tractor and am trying to get it running. I was very happy to come across all the original paperwork.
PS Ferguson
04-21-2008 06:57:15
I have a 1614 Powerking, last summer the electric PTO worked fine. Started to use it this spring and it wont work. There is electric going to the unit. Any suggestions, these are expensive and hard to find
Jeffrey E. Kennedy
03-25-2008 17:52:58
Wanted to thank everyone who has helped with this problem.No nothing has worked yet.I'm still working on it maybe I'll figure it out some how.
Joe M(GA)
03-24-2008 16:13:28
see if this helps -
Photobucket
El Toro
03-24-2008 03:48:58
See if this will help. Hal
PS: You don't want any battery voltage fed to these electronic modules.
G. L. Perry
03-23-2008 20:59:39
Go to Yahoogoups.com and join the PowerKing group there for info and look at the info on he left side of page to see more items. Most PK owner's manuals have a few diff wiring diagrams in them, you have to figure which one you have. Yes, you can get the wrong switch, a common mistake. Do you have points? Some don't and just spinning the flywheel should get a spark as long as it's kill wire isn't grounded. Some guys put a second toggle switch on for killing the engine on reworked tractors.
stronics
03-23-2008 15:00:20
What engine? What HP? Pointless ignition, is it Kohler?
David
Jeffrey E. Kennedy
03-23-2008 15:15:44
 Re: Power King Tractor 1970 in reply to stronics, 03-23-2008 15:00:20
14 H/P Kohler M/N K321S Spec.#60132b S/N 3288745 It's on a 1970 1614 powerKing tractor.
Jeff
03-23-2008 10:38:55
Did you just replace the ignition switch? If so, they may have given you the wrong one. It's easy enough to do but can cause some problems.
Jeffrey E. Kennedy
03-23-2008 11:29:26
 Re: Power King Tractor 1970 in reply to Jeff, 03-23-2008 10:38:55
No the switch that's on there came with the tractor.All my diagrams show different ones.Like one with only 3 tabs,and four.My helper hasn't had time to help.I bought the tractor and would like to get it running.
Jeff
03-23-2008 17:48:31
 Re: Power King Tractor 1970 in reply to Jeffrey E. Kennedy, 03-23-2008 11:29:26
I just looked through a lot of my paper stuff and found nothing. I have some CDs that I will reference tomorrow if I get the chance and see what I can come up with.
Copyright © 1997-2015 Yesterday's Tractor Co.
