LX-176
Ga-fla
11-08-2007 18:32:23
with no fire and coil,ignitor.plug all been changed. 14 hp kawasaki 15 years old only owner and sensors on seat,brake,blade all been bridged any help will be appreciated Dwayne
joe csuti
11-09-2007 18:36:01
 Re: LX-176 in reply to Ga-fla, 11-08-2007 18:32:23
The reading you are getting with ohmmeter between + battery cable & plug lead may be perfectly normal depending on design of electronic ign & coil connections to same,you may be reading thru the electronics or coil winding,as to flywheel key even if it were sheared & flywheel rotates you still would have spark,but out of time with eng,the exception being a point type ign when flywheel key shears & flywheel rotates on crank and points are not in time with magnets/coil position.
joe csuti
11-09-2007 03:16:14
Locate & disconnect ign kill lead where it exits eng,check for spark,if no spark,disconnect oil pressure sw or low oil cutoff,check if eng has hi-temp sw,if it does disconnect & check for spark,if still no spark problem in ignition parts,coil air gap or possibly a missing/weak magnet on flywheel,if you have spark after disconnecting ign kill lead,problem in safety sw's,ign sw or wiring on tractor.
Ga-fla
11-09-2007 17:49:09
 Re: LX-176 in reply to joe csuti, 11-09-2007 03:16:14
thanks Joe will check, with battery out 1 lead on pos post and other lead on spark plug wire, i have a soild short with the switch in the on position.i am taking the flywheel off to check for sheered key Dwayne
