Ignition timing, K301 in 1250 Cub Cadet
oldrustycars
10-05-2007 16:01:06
New points in my 1250 CC. Having trouble locating the timing mark on the flywheel. Carb side, round hole, all I can find is what may be "T", but might be just a line. Ran carb cleaner all around the flywheel while spinning the engine over, then blew it out with air. Shined a flashlight in the hole while slowly turning the engine over, this is all I"ve found. I set the points for this mark, seems to run OK, but now the point gap is only .009, down from .020 initial setting. Sound right to you guys? I"ve always had "SP" and "TD" for timing marks, using "SP" for the timing.
oldrustycars
10-06-2007 08:54:10
 Re: Ignition timing, K301 in 1250 Cub Cadet in reply to oldrustycars, 10-05-2007 16:01:06
well....looks like I'll be doing more to this one than I thought. Gotta dig that flywheel outta there now. Thanks for the replies, gentlemen.
lucas boy
10-05-2007 20:09:52
those has two marks,,s and t. points set on s mark. usually rust is hiding the marks .
oldrustycars
10-05-2007 19:31:09
Thanks, R Bedell, I know how to do this, done it many times. My question has to do with the lack of a timing mark on the flywheel. Are there some that have only a line or a "T", or do they all have the SP and TD markings?
R Bedell
10-06-2007 03:19:07
 Re: Ignition timing, K301 in 1250 Cub Cadet in reply to oldrustycars, 10-05-2007 19:31:09
Oldrusty:
I have had some markings that were barely stamped into the flywheel. Only after cleaning and polishing the flywheel edge with 300 grit sandpaper, did I see the markings. Once I uncovered them, then I added a dab of paint for future reference.
R Bedell
10-05-2007 17:08:07
Click on this link...
