I have a case 446, (purchased new in 1983). Over the last several years, I have had hydraulic problems. I am on my 3rd pump in 4 years.Recently, something got jammed in the rototiller. The hydraulic hose blew off the resivoir, and all the fluid came out. I replaced the flexible hose, tightened it, and replaced the hydraulic fluid with hydraulic fluid. The tractor sputtered for less than a second when I turned it on, and it hasn't moved since. I have since heard that the Case 446 dosen't use hydraulic fluid for the hydraulic system, but instead uses motor oil. If that is true, (is it?) have I damaged the hydraulic pump by putting hydraulic fluid in it? Should I drain it and put motor oil in it? If I have to replace the hydraulic pump, do I use hydraulic fluid or motor oil? Also I have just heard that I may have to bleed the air out of the line, and that the tractor will run if I do that. It makes sense to me. Is that true? If so, where do I bleed the line from? Also, can someone tell me where the hydraulic pump is located on the tractor? Thanks. Mike McPhillips
