LT 133
Vern
06-22-2007 22:18:38
I have a 1999 LT133. There seems to be a kind of rettling noise from the transaxle area. I can't find a fill/check plug anywhere on the case.
Is there one & if so where?
Vern
boog
06-26-2007 05:17:10
 Re: LT 133 in reply to Vern, 06-22-2007 22:18:38
All LT133s had sealed rear ends with grease in them. There is also a filter in there but you have to take the case apart to get to it.
Terrance DeBoer
06-23-2007 16:42:14
Not all JD lawnmowers have fillable transaxles. Some are sealed units that are full of grease. If it can be filled with low viscosity hy gard then there should be a fill tube with the dipstick in it on the transaxle. If you looked it over and dont see one then it is a sealed unit.
Vern
06-23-2007 21:09:53
 Re: LT 133 in reply to Terrance DeBoer, 06-23-2007 16:42:14
Terrance;
Thank you.
Vern
