JD LX176 - Blown Fuse
Jeff in MD
04-07-2007 09:51:17
Hi, In getting my LX176 ready for the Spring, I tried to fire it up and got nothing. I started with the lowest price part and one of the 15 amp fuses was blown (the top one on the panel). I looked for any obvious shorts, but found nothing. I have a volt meter and am in the process of checking to see where the short is. Any suggestions to help narrow the search would be great.
chevy65
04-09-2007 08:55:08
 Re: JD LX176 - Blown Fuse in reply to Jeff in MD, 04-07-2007 09:51:17
Does it blow a new fuse right away????? ????? ?
Jeff in MD
04-12-2007 18:06:06
 Re: JD LX176 - Blown Fuse in reply to chevy65, 04-09-2007 08:55:08
Tks for the reply. I was able to diagnose the problem after all. The solenoid on the fuel pump bowl had rotated around and was shorting out on the oil filter. I simply loosened the nut, rotated the bowl, replaced the fuse and voila.
