JD 316 ignition switch wiring
fredmich
07-25-2006 19:19:42
Can someone enlighten me to what wire goes where on the ignition switch? There is no plug just individual wires. ON the back of the switch is 5 terminals and they are marked S, B, R, A, I. The S is a terminal that is above the rest of them in a block of 4. Thanks.....Fred
fredmich
07-26-2006 07:47:48
 Re: JD 316 ignition switch wiring in reply to fredmich, 07-25-2006 19:19:42
It is a Kohler K341AS. The tractor began dieing while the mower was engaged. Then it would die as soon as the PTO switch was engaged. IT would start back up again and die after running less than a minute. Then it failed to start at all. The seat switch has been disabled and the wiring is a mess under the hood with no plug and individual wires going to the ignition switch. The PTO, Ignition and nuetral switch seem to be doing their job according to my ohm meter. I suspect the wiring. Thanks for the response. The serial no. is 0316G 089056M. ..... Fred
chevy65
07-27-2006 04:44:20
 Re: JD 316 ignition switch wiring in reply to fredmich, 07-26-2006 07:47:48
starting single terminal on top
top single Purple
next row dowm left double pink
right Red
bottom row left Yellow right Green
That should do it
fredmich
07-27-2006 11:27:16
 Re: JD 316 ignition switch wiring in reply to chevy65, 07-27-2006 04:44:20
Thanks Chevy65, I thought you had forgotten me! I assume that you are looking at the back of the ignition switch and not the plug. Is R for the wire from the regulator? A for accessory? I for ignition? B for battery? S for solenoid or start? It sure would have been nice if JD would have put the wire diagram in the owners manual with colors and discriptions. I sure appreciate your input. Thanks .....Fred
Chevy65
07-28-2006 15:24:12
 Re: JD 316 ignition switch wiring in reply to fredmich, 07-27-2006 11:27:16
Fred It sounds like you got it right
Yes looking at back of connector
The wire colors I give you are correct out of jd manual
It dont tell letters for terminals but if memory serves me you got it right
Bob
07-25-2006 23:20:50
There's supposed to be a molded plug. Offhand, I can only rmember a couple...
S= "Start" = purple wire.
B= "Battery" = red wire.
chevy65
07-26-2006 04:36:44
 Re: JD 316 ignition switch wiring in reply to Bob, 07-25-2006 23:20:50
Is this 316 a single or twin clyinder engine
sounds like a single
I can get the color code for you
purple is start Red is battery
Yellow is asseries Pink is saftey Black is ground
Ill get back with you
