Points gap Kohler k301 12 hp
Jimmyjack
07-07-2006 15:53:44
What is the recommended gap for this engine and tips for installing without a light?
JT
07-08-2006 07:15:29
 Re: Points gap Kohler k301 12 hp in reply to Jimmyjack, 07-07-2006 15:53:44
They start at .020, the you have to have a timing light to get it correct. By not having a timing light, you may run out the engine out of time and by running out of time, you can blow a head gasket or blow a hole out in the head itself. You can go to Auto Zone and borrow a timing light if you do not have one. I have had them run anywhere from .017-.022 when properly timed, so a timing light is pretty critical.
Jimmyjack
07-10-2006 14:00:15
 Re: Points gap Kohler k301 12 hp in reply to JT, 07-08-2006 07:15:29
A timing light or a dwell meter? I havent used one for years. I appreciate the help.
JT
07-11-2006 06:05:20
 Re: Points gap Kohler k301 12 hp in reply to Jimmyjack, 07-10-2006 14:00:15
Timing light, you have to set the points so they open at the timing mark on the flywheel, there are no exceptions to this at all. There can be a lot of variations due to wear on cam, wear of push rod, etc, so timing light is the only way to be 100$ accurate.
Jim
oldrustycars
07-08-2006 07:31:24
its true what JT said. i though i would be smart and set it with the light "this one time", measure the gap, then never have to use the light again. wrong. also, using a timing light seems to make the points last longer. 5 years old in my cub cadet 124, checked them this spring, clean with no pitting after 5 seasons of mowing.
Bob
07-07-2006 23:15:28
Service Manual link:
oldrustycars
07-07-2006 20:00:51
be a sport and get a timing light. you"ll be amazed at the difference.
R Bedell
07-07-2006 17:27:16
Gap = .020"
