Mark Master garden tractor Or MTD 995A INFO????
Jon Schick
08-18-2005 07:06:03
I have a large garden tractor with a 3pt hitch, hdro, it's a Mark Master and only info I can find is possibly it's a MTD 995A (possibly like a 143-995) any info would be helpfull, I have no idea what year it is but around 1980-89 I think it has a Kohler, its all shaft drive to trans and deck. problem is it only moves very slow, neighbor changed a trans hose and then put Car tranny fluid in it, and it hasn't moved since, what fluid should be in it? and is it likely toast? is it worth anything?
Les_from_Syracuse
08-18-2005 08:40:32
 Re: Mark Master garden tractor Or MTD 995A INFO?? in reply to Jon Schick, 08-18-2005 07:06:03
I have a 96 White 2055 that is a 900 series MTD tractor, model 146-992-190 that sounds similar to what you're describing. The brake on mine hangs up once in a while causing it to move very slowly. When I release the brake, I always put my toe under the brake pedal and pull it up. The trani on my tractor can take a whole range of fluids including auto trani fluid, but the recommended fluid is 20 Wt engine oil which I find at a farm supply store.
jon schick
08-18-2005 10:20:52
 Re: Mark Master garden tractor Or MTD 995A INFO?? in reply to Les_from_Syracuse, 08-18-2005 08:40:32
thanks,
I also found out that it should be the same as the White GT1855 from 1985-1987 range, so yes I bet it is similiar to your 2055.
thanks
Les_from_Syracuse
08-18-2005 10:55:26
 Re: Mark Master garden tractor Or MTD 995A INFO?? in reply to jon schick, 08-18-2005 10:20:52
Let me know if you'd like a copy of the manual. I could probably scan it and send it via email.
