JD 262
JD JOE
07-05-2005 19:48:29
I have a JD262 tractor. It has a ton of hours on it. Now whe it gets hot it dies and wont start untill it cools off. Ive been told its the coil. Checked at the dealer and they want 90 bucks, can i go to napa or somewhere else and get a coil the will fit? or do you think it migth be something else.
Thanks
ECHOMASTERSERVICETECH
07-06-2005 02:23:37
 Re: JD 262 in reply to JD JOE, 07-05-2005 19:48:29
YES PARTS CAN BE BOUGHT THROUGH NAPA, I THINK THE PART YOU ARE LOOKING FOR IS THE IGNITER NAPA NO. 7-01760.THIS IS MOUNTED ON SIDE OF ENGINE. IF IT IS IGNITION COIL YOU ARE TRYING TO GET PROVIDE NAPA WITH YOUR DEERE PART NUMBER AND THEY CAN DO THE REST. PROBLEM IS MOST LIKELY IGNITER.
Bob
07-05-2005 21:19:33
I don't see a model #262... is it a model 265???
What was the part number of the coil they quoted you on???
teej
07-05-2005 23:37:24
 Re: JD 262 in reply to Bob, 07-05-2005 21:19:33
There is a GT262, perhaps thats what he meant??
Mazz
07-05-2005 20:39:21
Joe - If you can find the specs on the JD coil, and match it, you might be o.k. The problem is going to be finding the specs on the JD coil.
