JD L118
harvey2fords
07-05-2005 12:20:41
My year old L118 has started running very rough under load (belt engaged, mowing weeds). Runs smooth with out load. Almost sounds like one of the 2 cylinders not firing all the time. Has had regular oil and plugs change. Has anyone had similar problem and any suggestions??
Thanks!
warranty
07-10-2005 07:06:45
 Re: JD L118 in reply to harvey2fords, 07-05-2005 12:20:41
Isn't the tractor under warranty? How many hours are on it?
pdi man
07-05-2005 17:55:11
check for spark, then check into carb. those have a two barrell carb. have seen them stop up on one side and cause one bank to run lean. makes muffler glow and such. new carb cures this. darn emmisions carb can"t really be cleaned. takes about an hour to switch one out. real pain to remove, but not complicated.
repaired several last year for same issue.
scott
harv
08-12-2005 07:10:27
 Re: JD L118 in reply to pdi man, 07-05-2005 17:55:11
PDI Man (and all others)I hate to admit this, but the problem seems to have cleared up itself. Shortly after posting problem, my Mom got in very bad shape, buried her last week, and wife had to have surgery. No time to mess with the JD. Apparently the grain of crud in the carb disolved itself. I must admit I was pulling the choke back only a bit when mowing; son-in-law recognized stupid and showed me to pull it all the way off after warming up (only moments). For whatever reason(s) the JD is running just like new. I do appreciate the suggestions and don't go away. Will probably be back later.
Thanks again,
Harvey
harv
07-06-2005 04:33:46
Thanks for the information. Sure sounds like it. I'll let you know what develops.
JT
07-05-2005 13:04:21
What engine is in the L118?
MStonge060698
07-17-2005 08:10:00
 Re: JD L118 in reply to JT, 07-05-2005 13:04:21
The Home Depot JD L118 is a 22HP Briggs. Was just looking at it yesterday.
harvey2fords
07-05-2005 13:17:50
L118 JD from Home Depot has a 20 hp Briggs.
All suggestions entertained!
thanks
youngblood
07-05-2005 17:34:51
 Re: JD L118 in reply to harvey2fords, 07-05-2005 13:17:50
it could be the coil pack they have had some bad one on commercial mowers check tha and go from there
