Wheels frozen on Snow Blower Axle
Frank M. Slapar
03-22-2005 19:44:52
We purchased a Snow Blower this past winter and the wheels are rusted on the axle. The wheels each have pins in them so that they can be loosened by removing the pins. This would allow us to transport it easier.
Do any of you on the forum have some suggestions in regard to loosening the wheels? I have tried hammering on them lightly but that does not seem to do the trick.
Any suggestions would be appreciated.
Leland
03-23-2005 19:57:07
 Re: Wheels frozen on Snow Blower Axle in reply to Frank M. Slapar, 03-22-2005 19:44:52
Try mixing brake fluid and 2 stroke oil about 70-30 more brake and use this mix it's a great rust buster and cheap.
blue diesel
03-23-2005 16:21:14
I don't know if anyone will agree with me but sometimes you will NEVER get it free. We had a Gilson rear tined tiller that we soaked and beat on so long the guy gave it to us(9 months). Being the type of guy with the "I can do it" attitude, I cut the wheels off with a saw-zall, saved the shaft, and put on Ariens wheels with pnematic tires. I've got a 724 Toro two-stage, that I've got the quick pins out of the axle, that I use for a snowblower(with and without chains). I use all types of "spray and pray" on it every year since we took it in on trade(1992) and they(either side) never broke free. Some repair jobs,I've cut them off at the axle, heated them cherry red and in the arbor press I still couldn't get the stub to move. But yes, some do come apart. An aircraft bit and drilling between the axle and the wheel help get rust penatrant down there. GOOD LUCK and keep beat'in
supergrumpy
03-23-2005 09:42:01
had exact same problem with old Sears, have to be careful not to ruin the wheel
soak both sides of the wheel/axle join with PB Blaster, spray every 3-4 hours for several days, wipe excess PB off the rubber unless you plan to replace the tires
with pin out, use old deep socket (expendable one) that will just slip over axle and rest on edge of wheel rim
beat the snot out of that socket with 5lb sledge until wheel moves just a smidgen, re-spray with PB Blaster and let it sit a while
once you get it moving, you are 85% done and can usually spin it off by hand, K-roil is said to work even better but I have never used it
Kent of SW MO
03-23-2005 06:38:31
If all of the above does not work, the only thing left is to heat with an oxy./act. torch and heavy hammering.
Kent
RWK in WI
03-23-2005 04:45:37
I have had luck with pulling the drive pins out and soake the area with Kroil oil and then using the unit to power the wheels - pushing against a tree or truck / tractor plow or other solid part ( augers stopped ) - the weight of the unit on concrete gives good traction and the axle spins in the wheels.
Dannie
03-23-2005 01:47:41
Try PB Blaster on both sides of wheel leave over night.
