John Deere 112 wiring diaghram
Dave Cregar
12-04-2004 19:21:50
Somebody has put an aftermarket ignition switch on the 112 and I bought the original oem to replace, I need to find the correct diaghram for it, they cut the plug off on the end too. It has the Kohler 10hp on it 1969 model. Any help would be great. Thanks
deano
12-05-2004 07:05:52
 Re: John Deere 112 wiring diaghram in reply to Dave Cregar, 12-04-2004 19:21:50
i will try...by written description..if your serial # 250k-260k. if you look at your new switch from the back, with the one spade on top...put purple wire on it..the next lower on on left of switch takes red/white wire this goes to ammeter..the right spade on that row takes pink wire that goes to stator..the bottom row on the left spade takes light green, that goes to rectifier..the right spade on the bottom takes 2 orange wires that go to the pto (other side of purple wire you hooked up) and the other orange wire goes up to electric lift switch...i hope someone reviews this for correctness, and i hope it helps you out dave...otherwise i'll see if i can't figure out how to post diagram....please don't get mad at me if i made a moosestake....
