JD LX 172
WIFarmall
08-12-2004 11:29:37
The electric clutch on my John Deere LX 172 does not engage. It is not stuck. Wires seem good. Where can I find a used one at a reasonable price? Any other ideas?
TheRealRon
08-12-2004 12:42:46
 Re: JD LX 172 in reply to WIFarmall, 08-12-2004 11:29:37
Did you actually test for 12V at the clutch? Yes, they do good bad but bad wiring/switches are more likely.
WIFarmall
08-12-2004 14:06:51
 Re: JD LX 172 in reply to TheRealRon, 08-12-2004 12:42:46
Thanks Ron. There is 12v at the clutch plug-in. Next step is to remove the clutch. Anything to watch for? I've never taken one off before. John
TheRealRon
08-12-2004 17:57:05
 Re: JD LX 172 in reply to WIFarmall, 08-12-2004 14:06:51
No, it's a piece of cake. But shop around for that clutch... JD is very pricey.
JT
08-12-2004 15:52:59
The clutch should come off in one peice. One bolt through the middle. One thing to check, though, some clutches are adjustable. But is it is not, take off the clutch, put 12 volts with a chrger to the plug and see if the clutch engages, we have found them to just have a improper ground causing it not to work. good luck
WIFarmall
08-17-2004 06:18:59
 Re: JD LX 172 in reply to JT, 08-12-2004 15:52:59
Thanks for all the help. I removed the electeric clutch on my JD LX-172. Put a 12v charger directly to the clutch. Nothing. Does anyone have a used clutch? Is there any place to get one at a reasonable price?
